TD6 Engine Coolant Circuit
Old Dec 30, 2024 | 05:39 PM
RyanLR3's Avatar
Default TD6 Engine Coolant Circuit
Curious if anyone has a coolant flow diagram and/or factory description of coolant flow for the TD6. Also curious what the 2 engine coolant temperatures are. #1 seems to be consistent with Normal operational temperatures of an engine ambient to ~190F. The #2 temp is normally significantly less than the #1, unless under towing or higher ambient temperatures. See GAP screenshot. Ambient temp at time of picture is 46F with the Discovery idling.
Old Feb 8, 2025 | 12:46 PM
RyanLR3's Avatar
Thoughts anyone? 😊
Old Feb 9, 2025 | 07:21 PM
gmfain's Avatar
Tomorrow I'll try and find diagrams.
What are the code numbers?
PXXXXX?
Old Feb 9, 2025 | 09:56 PM
RyanLR3's Avatar
PXXXXX?
I don't have any fault codes. Just curious what the second coolant temp and circuit does
Old Feb 10, 2025 | 07:18 AM
gmfain's Avatar
I don't think this is all, if you need more I'll try again.
File Type: pdf
Old Feb 10, 2025 | 07:19 AM
RyanLR3's Avatar
Thank you
sayvillerx
Jul 26, 2024 04:30 PM
Greg-2022
Sep 21, 2023 01:32 PM
mtaylo32
Jun 21, 2023 11:07 AM
Externet
Apr 26, 2023 08:58 PM
Rock Sing
Jan 18, 2013 02:17 PM
