Td6 Misfuelling Reset Tool Location
Old Sep 22, 2023 | 10:58 AM
clockwiseq's Avatar
7th Gear
Default Td6 Misfuelling Reset Tool Location
Today I learned that you could run out of fuel if you pull up to a service station and you go to put fuel in your Disco and the nozzle won't go into the fueling hole. I've been to this station 100 times and used this particular pump 100 times and never has this ever happened, but today it did. I left embarrassed and without fuel and now I have about 6 miles to empty. Immediately Google'd this issue and found out that this is some type of brilliant device that the geniuses at JLR decided would keep stupid people from putting gas in their diesel Disco called the Diesel Misfuelling Detection Device. Yay.
So, after learning what the problem is, I learned that I should have a yellow tool to reset this device. Does anyone here know where the tool is usually stored?
Old Sep 22, 2023 | 11:17 AM
sowrco's Avatar
Interesting. My pre-owned came with a white tube, which I found in the glovebox, but I think that''s for filling up from a jerry can?
I had this happen to me once, I drove a few miles down the road to another station and the flap had reset all by itself. I didn't have to do anything, and I refilled successfully.
Old Sep 22, 2023 | 11:19 AM
clockwiseq's Avatar
7th Gear
Oh! Ok, I'm a few miles from the station, so maybe mine has reset. I will go check it and see. If not, I will check the glovebox for a white tube. Thanks for the reply!!
Old Sep 22, 2023 | 11:38 AM
clockwiseq's Avatar
7th Gear
Well, no such luck. Opened the gas cap and still a metal plate is blocking the hole. I also scoured the vehicle and every nook and cranny I could find and no reset tool to be found.
Old Sep 22, 2023 | 03:08 PM
sowrco's Avatar
Did you check under the rear storage floor for the reset tool? It might be there. Or perhaps in your jack/brace kit on the right side, rear storage.'
Old Sep 23, 2023 | 07:47 AM
ar077's Avatar
What you're looking for is Fuel filler cap misfuel flap reset tool for Land Rover Discovery 5 (LR014047). If the dealer doesn't have it, you can order it from www.PowerfulUK.com.
Old Sep 24, 2023 | 08:02 PM
canon_mutant's Avatar
Hmmh, we have not had the pleasure of this happening but good to know . . .
Old Sep 25, 2023 | 07:12 AM
clockwiseq's Avatar
7th Gear
Ok, so I was wondering why I couldn't find any video or specific information about the reset tool for a Discovery 5 and that's because it changed in 2017. It now has the black trigger at the bottom of the hole and the problem was that the station I normally use had maintenance done and the technician installed a gasoline nozzle on the diesel handle and I simply didn't notice that it was thinner. There's honestly such little difference in size that it's easy to overlook. BUT, after a trip to the dealer and our normal service person came out with "the reset tool" which turned out to be the DEF funnel, we noticed that when he inserted the funnel in the hole, it was pressing down on the black plastic piece of the hole and would allow it to open. So, for anyone here that experiences this, just know that there's no locking device that has to be reset on a Discovery 5, just have the right size nozzle. If you pull up to a pump and it's not the right size, you can use the DEF funnel as an insert because it's the perfect size to disable the misfuelling flap.
Old Sep 25, 2023 | 03:15 PM
sowrco's Avatar
Good information. Thanks. That might explain why when I moved to another gas station down the road I could pump fuel.
462disco
Sep 22, 2025 12:15 AM
TonyHammer61
Range Rover L405 (Fourth Gen)
Jul 24, 2023 08:56 AM
quirozson
Feb 3, 2023 06:42 AM
LR Max
Jun 4, 2021 08:03 AM
mr. choodles
May 21, 2018 09:22 PM
