For those with diesel Td6....ACEA C1 is going away
Old Jun 1, 2021 | 10:25 AM
AirRyan's Avatar
Default For those with diesel Td6....ACEA C1 is going away
JLR likes to spec an ACEA C1 oil for use in our USA Td6's, but most dealers don't even carry a C1 oil. (Ask them which ACEA spec the bottle says, it's probably a C3 oil.) Fortunately, ACEA for 2021 is doing away with the C1 spec.
Ford (who built your Td6) says to run a CK-4 oil which is a 5w-40 if you encounter ANY biodiesel. Sure, the F-150 Power Stroke V6 diesel has a different SCR after-treatment system but it is otherwise the same long block. FCA did the same with their EcoDiesels in 2015 when they went from a 5w-30 oil spec to 5w-40, (which was to help protect the bearings.) Your motor, you decide. I suggest an ACEA C3 5w-40 like Motul's 8100 X-clean Gen2 5w-40. If you can find TRIAX EURO VX 5W-40 Full Synthetic, that looks like a good oil, as well.
https://www.acea.auto/publication/ac...equences-2021/
geekinc
Nov 13, 2023 04:35 AM
the420star
Aug 1, 2015 06:51 AM
shady milkman
Mar 1, 2013 09:20 PM
ESPN
Sep 4, 2011 09:31 AM
DiscoRom
Nov 23, 2008 09:01 AM
