Tire Pressure 275/55/20
Old Dec 9, 2020 | 09:44 PM
adamLeee's Avatar
6th Gear
Default Tire Pressure 275/55/20
I just went to a larger tire (275/55/20) and I’m curious if I can run lower tire pressure and if anyone has found the sweet spot?
Old Dec 10, 2020 | 09:19 AM
TexasLandmark's Avatar
Neat. Yours looks like our eiger gray landmark. We run a 275/55r20 bfg ko2s on our offroad set of wheels that i installed tpms in too... running at 37ish and feels fine. I haven't tried to fine tune it past just setting them there. You need to go in to your menu and set the "tyre" pressure to light load... i think if you go under 41 psi while on regular setting it will give you tpms warnings.
link to menu sequence: https://landroverforums.com/forum/ne...e5/#post744096
Old Dec 10, 2020 | 10:06 AM
adamLeee's Avatar
6th Gear
@TexasLandmark Yes, 2020 eiger gray landmark as well. Your truck looks great. Thanks for the input on the tire pressure. I’ll have to play with it a bit. The tire shop set it too the factory settings (47 Front, 51 Rear) and it’s a bit much.
Old Dec 10, 2020 | 10:23 AM
Pretty sure that factory setting is for fuel milage and weight ratings while loaded so that they don't have legal issues. Comfort isn't factored in... i would wonder if jlr reps lower the pressures before handing over press fleet vehicles lol, it'd be smart.
I have no idea what pressures are best for tire wear.
me6067
Aug 8, 2015 11:01 AM
LR03NJ
Tires
24
Mar 19, 2015 01:08 PM
Silver_Slug
Aug 2, 2013 07:05 PM
ESPN
Nov 3, 2011 07:28 PM
oncorhynchus
Jan 21, 2007 02:14 PM
