Tires Choices for D5 w/out Air Suspension
Old Jul 15, 2021 | 08:22 PM
generals1992's Avatar
Default Tires Choices for D5 w/out Air Suspension
Just got a nail in the sidewall of one of my tires. I’ve got the original Pirelli 255/55/20s with about 24,000 miles on them. My shop is telling me they have about 4/10 of tread left which would translate to around 7,000 miles left…currently will replace for around $350/tire.
My two questions are this:
1. Can I go up to the 275/55/20 tires that are recommended around this site? Assuming most of those are recommended for the air rides and not sure if I might have clearance issues with the coil springs.
2. should I replace all four?
As an OCD person, I hate the idea of having tires with different levels of wear - and if I replace one now I’ll be saddled with buying three more mediocre tires in about 6 months. But I hate the idea of not squeezing every ounce out of the tires, especially considering that I bought this car CPO 4 months ago and feel that I should be getting much more life out of these things.
Assuming I do replace all four and the 275s will fit - what have been the more popular selections here? I’ve had Nitto TGs on previous Jeeps and like the look but not sure I need something quite as aggressive. Would be going for the rugged look with hopefully minimal compromise on longevity and ride quality this time around.
Old Jul 16, 2021 | 07:42 PM
BritCars's Avatar
CPO has a min tread requirement. I'm surprised that after 4 months you are down to 4/32nds (or is it 4mm) remaining. Unless you did a lot of miles?
If it were me I'd replace all 4. I try not to run all the way to bare.... And you can often get a cash discount (Eg $100) when you buy a set of four.
Why do you want to change tire size? What's the objective? I run the stock size you have and are v pleased with them.
Old Jul 18, 2021 | 01:23 PM
n559br's Avatar
I went with stock size Toyo AT3s, for the 3/4 inch gained width the additional benefit didn't outweigh the cost adder.
Old Jul 19, 2021 | 02:08 PM
I want something a bit beefier than the stock tires that were on the car and there seem to be more options at the 275 level. I went with the Pirelli Scorpion AT Plus 275/55r20. Should be picking it up today and will report back once I take it for a spin.
I am a bit perturbed that I’m already replacing these tires. I bought the vehicle with 17,000 miles and am a hare over 23,000. I feel like I should be compensated, although my experience with the dealership and LRNA on a prior issue has me feeling like I’m not going to get anywhere and it’s not even worth the time. They have been truly awful and I’m not sure I have the time to fight this one, especially since they do technically have another 7,000ish thousands miles left of life and I’m choosing to replace them now.
rikitik3
Dec 7, 2020 09:21 PM
Groucho123
Oct 20, 2018 11:06 PM
ShadowMerchantBC
May 24, 2011 12:24 PM
trev0006
Tires
Nov 4, 2009 09:33 PM
jycsalas
Apr 3, 2009 03:33 PM
