Tires for Non Lifted
255/55/20's are 30.1" and 275/55/20's are 31". Tons of options at the 275 profile, only two that I know of at the 255 OE spec; Falken Wildpeak A/T and Goodyear Duratrac. If I go to 275 I would look at some Hankook Dynapro AT M's, they looked like a decent AT tread while still being quiet enough on the road. I looked at a 2018 HSE Lux Td6 that had 275/55/20 Duratracs and I thought at the lowest suspension height, if turned all the way, they would slightly rub. But, that probably isn't an issue since any off-roading would be done at a higher height. Discount Tire has an exclusive Goodyear Ultraterrain tire available in the 275/55/20 size, very comparable to the Duratrac's but at a better price.
https://www.whichcar.com.au/gear/whe...s-product-test
https://www.falkentire.com/tires/lig...k/t-trail-tire
https://www.discounttire.com/feature...ltraterrain-at
Looking forward to the pics.
Most 275/55/20 options fit with no lift and no rubbing looking at all the posts here and elsewhere. However some of the more aggressive 275/55/20 options may have some rubbing with no lift. I believe canon_mutant tried to fit Nitto Dura Grapplersbut they rubbed on the spindle and had to use the Geolanders. When the Pirellis wear out, likely before next winter, I will probably go to the Geolanders, not as aggressive, bu good for my wife as a daily driver.
275/55R20s fit I just put on a set last week. The new Pirelli AT plus and they are fantastic tires. Rides like it did with the good year f1 highway tires.
The following 3 users liked this post by vulturez:
