Trailer hitch bounce
Mine does the same thing. I think the receiver is larger than 2". I don't think you have to worry about the trailer jumping off if you have the proper tongue weight, but it does make a racket. I thought about wrapping a couple rounds of electrical tape around the shank of the hitch to quiet it down?
6000lbs of boat with fuel sloshing around gives a rough as hell experience that CANT be good for it.
I think I had used thin double sided tape, but only put it on the hitch, without removing one side of the tape if that makes sense. I don't have this problem on the LR3, but I think I did on the Range Rover. I did do something on the trailer that I tow all the time, I added 100 lbs in tongue weight as the trailer has a tailgate, with that weight the front of the trailer is was a little light when empty and would rattle like no tomorrow. With weight it was fine, or without the tailgate as that is removable. Basically the tape prevented steel on steel, and that eliminated majority of the extreme noise. The two 50 lb weights simply made it perfect, and it rides much better.
