Turbo
Old May 28, 2024 | 05:23 PM
jaacina's Avatar
Default Turbo
I have coolant coming out of my intake pipe. Seems likely that my turbo is leaking coolant. Can the turbo be removed from the TDV6 without lifting the body or pulling the engine?
Old May 29, 2024 | 09:10 AM
sowrco's Avatar
There's no body lift on the D5 - it's unibody.
Old May 30, 2024 | 05:53 PM
RyanLR3's Avatar
The turbo is lubricated/cooled with oil. If you have coolant in your intake it could be an issue with your air/water intercooler. Think land Rover calls it an auxiliary radiator. It's behind the RH front bumper. No experience with them leaking in this application but I'd almost expect to see coolant on the ground if it's leaking enough to see coolant n the intake system
https://www.rockauto.com/en/catalog/...,radiator,2172
Old May 31, 2024 | 04:32 PM
jaacina's Avatar
The diesel are air to air intercoolers and the turbos are in addition to oil cooled/lubricated is also water cooled.
Old May 31, 2024 | 05:06 PM
RyanLR3's Avatar
Are you saying there is water plumbed directly to the turbo on the TD6?
Old May 31, 2024 | 09:55 PM
jaacina's Avatar
Yes. Water cooled turbos are not uncommon.
This engine uses a Garrett GTB2060V Turbocharger.
https://www.garrettmotion.com/racing-and-performance/choosing-a-turbocharger/water-cooling-for-your-turbo/#:~:text=Many%20turbochargers%20are%20designed%20w ithout,cooled%20by%20oil%20and%20water.
Old May 31, 2024 | 10:03 PM
RyanLR3's Avatar
https://www.garrettmotion.com/racing...%20and%20water.
I understand that much. Confirming we know specifically the TDV6 is.
Old May 31, 2024 | 10:23 PM
jaacina's Avatar
I have confirmed. Rock Auto has bad info when looking up via the referenced LR part numbers.
My 6.7 Powerstroke uses a water to air intercooler. It's pretty impressive.
Old Jun 1, 2024 | 10:38 AM
RyanLR3's Avatar
I misspoke previously. The aux radiator does cool water that passes through the air/water intercooler which is located behind the LH front bumper. I suppose the intercooler itself could be leaking water into the intake air charge. Confirmed the single turbo setup is water cooled. Water pipes to turbo circled. Very cool
Old Jun 1, 2024 | 09:25 PM
jaacina's Avatar
I think I am going to investigate more and look at the intercooler.
bluewin2
Jun 21, 2023 07:46 AM
Stephen Novak
Feb 8, 2020 01:27 PM
Dave Haynes
Defender
Sep 29, 2019 08:46 AM
RustRover
Sep 8, 2012 09:27 PM
Satisfying Pie
Jan 8, 2011 11:24 PM
