Tyre Pressures for Towing Caravan?
Old Apr 7, 2023 | 02:23 PM
Baker69's Avatar
5th Gear
Default Tyre Pressures for Towing Caravan?
Can anyone advise on the best tyre pressures for towing a caravan (1700 Kg laden)? The tyres fitted on my Disco 5 HSE are 285/40/R22.
I see the tyre pressures for normal vehicle loading are 34 at the front and about 36/37 rear, my gut instinct is to go 35 psi in the front and 38 to the rear?
Old Apr 7, 2023 | 09:26 PM
BritCars's Avatar
Are you sure? That sounds very low
My 2018 Discovery says 44 front and 50 rear...
Old Apr 8, 2023 | 03:27 AM
Baker69's Avatar
5th Gear
I did find one site which states the pressures you refer to but all of the rest (including the vehicle’s own TPMS) say around the 33 or 34 psi mark for normal driving use.
Old Apr 8, 2023 | 09:48 AM
Baker69's Avatar
5th Gear
On the vehicle plate it does state 44 & 50 for fully laden (7 people plus luggage). It seems a lot considering the stock Pirelli Scorpion tyres fitted state 50 psi maximum pressure?
We towed our caravan for the first time today since we bought the Disco 5, I upped the front tyres to 36 psi and rears to 38 psi and everything seemed fine. Not everything was fully loaded though as it was only a trial run.
Old Apr 8, 2023 | 10:59 AM
David42six's Avatar
I know this doesn't precisely answer your question regarding tire pressure for towing. I will share my opinion, which is that the normal pressure recommendation is for a loaded vehicle, towing or not. I tried the normal pressure recommendation in an unloaded vehicle and I found the ride to be harsh. I've included pictures of the TPMS suggestions and the pressure I use unloaded. I have the TPMS set to "light." I have pulled a light trailer for a short distance like this and it felt perfectly fine. Again, the vehicle itself was unloaded. I run 255/55R20 Michelin Defender M+S. It looks like my right rear could use a pound!
Old Apr 8, 2023 | 08:08 PM
BritCars's Avatar
Yes. Per above there are two settings. Light and normal. We drive on normal all the time. Typically just our family (5 people) without much other luggage. Have done it for 5 years with no issues. Ride is firm but air suspension seems to manage that fine.
I can see doing lite for normal driving. But if I were towing I would definitely do the 'normal'.
Old Apr 10, 2023 | 11:38 AM
Donc98's Avatar
I have running the normal pressure setting when towing my RV now over the past year. I usually drop it down to the light load in between towing/family hauling duties and that does help with some of the crappy roads we have in Houston. (glad i only go into that city from time to time now). No issues with towing and the D5 is a solid tow platform.
LR disco 5
Apr 20, 2022 09:25 AM
LR disco 5
Mar 8, 2022 11:28 AM
LR disco 5
Feb 16, 2022 06:21 PM
Jull
Feb 14, 2011 07:33 PM
phill
Sep 24, 2005 04:02 PM
