What tire and wheel sizes if I go to 20”?
Old Jun 12, 2022 | 06:06 PM
JMV's Avatar
JMV
Default What tire and wheel sizes if I go to 20”?
Hi there,
I’ve got factory 22s with 285/45/22 rubber. I am fairly certain that’s a 9.5” wide wheel, and im
uncertain of the offset. Can anyone give me detailed info on what width and offset I can/should go with if I go to 20” wheels?
My goal is to go to 20s to fit bigger sidewall A/T tires. I think I’d like to go with Nitto Ridge Grapplers. So - if I can keep a 9.5” wide wheel, what 20” tire size would be the biggest I can fit without rubbing? 275/55/20?? Or could I go 275/60/20?? I would almost certainly do a 1.5” rod lift with this setup, BUT, I would like it to fit with a stock setup as well - just in case there are airbag failures or anything like that.
Any input is appreciated! Bonus points if you can show me pictures with details of your wheel width, offset, and tire size!
Old Jun 13, 2022 | 07:33 PM
LR disco 5's Avatar
275/55/20 will fit perfectly with no rubbing however 275/60/20 will rub slightly but with some trimming should fit.
Old Jun 13, 2022 | 10:09 PM
JMV's Avatar
JMV
Ok, thanks! Will that depend on wheel width? Still trying to figure out what the optimal width and offset is - and not sure if I want to try to pick up used factory 20” wheels or go with aftermarket (maybe redbourne?) wheels.
Old Jun 16, 2022 | 06:41 AM
Matthew424's Avatar
I have LR OEM 20" and their diameter is 255/55 R20.
Old Jun 22, 2022 | 06:40 PM
orangeman's Avatar
OH BUDDY HAVE I GOT A THREAD FOR YOU…
honestly Id recommend 275/55R20 on a Range Rover Sport wheel. Buy those toads on eBay and slap some discoverers on there
Old Jun 22, 2022 | 06:42 PM
orangeman's Avatar
https://landroverforums.com/forum/ne...62-td6-111766/
Scoot
Dec 12, 2024 03:55 PM
ardifan
Nov 19, 2021 01:45 PM
D.Warner
LR4
May 8, 2016 10:36 PM
Camdisco24
Nov 30, 2008 08:22 PM
matt
Mar 1, 2007 07:55 PM
