What's the oldest RR wheel that will fit?
Old Jul 16, 2020 | 10:59 AM
1979rover's Avatar
Default What's the oldest RR wheel that will fit?
Came across a few set's that might work.
These are 20's the seller says will fit 2002-20012 RR's
And these are 19's that came off a 2006 RR HSE
Any idea if these will fit? Trying to get a second set to put AT's on since I am currently on the OEM 21's
Thanks
Old Jul 16, 2020 | 02:28 PM
The DareDevil's Avatar
I'm running these (during winter) from the 06-09RRS:
Old Jul 16, 2020 | 02:31 PM
1979rover's Avatar
Been looking for something like that without much luck yet.
Are they 19's or 20's?
Old Jul 16, 2020 | 02:34 PM
20 x 9.5:
https://www.originalwheels.com/landr...rt2007rims.php
I used these sites to compare offsets and sizes between the models:
https://www.wheel-size.com/size/land-rover/discovery-5/
https://www.wheel-size.com/size/land-rover/range-rover/
Old Jul 16, 2020 | 02:40 PM
Summers:
Old Jul 16, 2020 | 02:50 PM
1979rover's Avatar
Just so I'm reading this correctly...
As long as the rim measurements are the same I'm good?
Old Jul 16, 2020 | 02:56 PM
Yes, that is correct.
Old Jul 16, 2020 | 07:26 PM
BritCars's Avatar
Almost. You also need the same bolt pattern. LR has been using 5x120 spacing for a while so you should be fine with those ones. But if you get an older or different brand wheel you need to ensure the bolt pattern is also the same - as well as width, diameter and offset.
Not sure how tight the brake calipers are to the barrel on the 19inch wheels but it's possible that wheel barrel shape will matter if OEM 19inch wheel is tight. Shouldn't be a problem for a 20inch wheel as there is a 19inch option so it would have to be a strangely shaped barrel to catch on the caliper. On some of the Jags with large brakes only a few 19inch wheels fit, the rest fowl the caliper due to wheel barrel shape
Old Jul 16, 2020 | 07:41 PM
BritCars's Avatar
Also - not sure what you're looking to spend. I got a set of LR 20inch OEM wheels on eBay that had been taken straight off a new car to use for my winter tires. Price was very reasonable. And they match my original ones.
Old Jul 17, 2020 | 09:31 AM
1979rover's Avatar
I'm checking ebay and local Craigslist. Not in a huge hurry, so will probably buy opportunistically.
The wheels listed above won't work. Going to stick with 20's from probably a 2012 and newer. That chart (and my understanding of it) helped tremendously.
Thanks all!
