wind noise
Given the reports of some D5s having water leaks by the windshield due to poor sealant application at the factory you may want to look into that. There may be an air leak that with enough pressure can cause noises and adjusting the cabin pressure offsets it.
At least I’m not the only one. It’s definitely coming from an upper part of the vehicle. I will check the sunroof seals and look at the windshield. I tried putting the air on recirc and that didn’t do anything. I haven’t had any obvious windshield leaks. It’s just an annoyance now, and not bothersome enough to make a dedicated trip to the dealer for it since they’re 45min away.
Since we finally had a nice sunny day here in Michigan, I was able to investigate more. I think it’s the sunroof. The weatherstripping on the right side isn’t quite as straight as the left. I left it open for a while to see if it “decompresses” a bit. I also put some silicone on it. We’ll see if it solves the problem.
