Would 275/60 R20 fit?
For the speed 'issue':
Speed difference is only about 1 mph faster than indicated at 30 mph, 2 mph faster than indicated at 60 mph.
255/55/20 is 280.5 mm plus 20 inches = 11.04 inches plus 20 inches = 31.04 inch diameter.
275/55/20 is 302.5 mm plus 20 inches = 11.91 inches plus 20 inches = 31.91 inch diameter.
31.91 divided by 31.04 = 1.028 = an increase of only 2.8 percent.
Varies a little by tire manufacturer.
Credit: ponderosajack for that information.
on
The calculator I show says at 60 mph indicated you'll actually be doing 64.
https://www.tyresizecalculator.com/t...ror-calculator
This calculator shows 60MPH as 61.9MPH using OEM of 31 inches and New as 32 inches (This being a simple approximation, not exact due to other variables not presented in the formula). Not sure what your inputs were for your calculation.
https://www.intercotire.com/calculat...re_size_change
