Would 275/60 R20 fit?
Old Jun 15, 2021 | 08:48 PM
1979rover's Avatar
Default Would 275/60 R20 fit?
I have a neighbor selling a set cheap.
just curious
Old Jun 16, 2021 | 12:40 PM
bkjecu94's Avatar
Not without cutting something... kj
Old Jun 16, 2021 | 01:17 PM
1979rover's Avatar
How much and where though?
Old Jun 16, 2021 | 02:28 PM
bkjecu94's Avatar
It ultimately depends on the exact tire you use since the specs are all a bit different depending on the brand... The only way to find out is to mount them and see where they rub.
Old Jun 23, 2021 | 06:30 PM
n559br's Avatar
Since stocks are 255-55*20 you would be going up in both diameter and width. Plus it's going to blow your speedometer. I would look at the online details on size differences between them. I think you'll lose some performance off road in addition to the speedometer reading.
Old Jun 24, 2021 | 08:31 AM
bkjecu94's Avatar
For the speed 'issue':
Speed difference is only about 1 mph faster than indicated at 30 mph, 2 mph faster than indicated at 60 mph.
255/55/20 is 280.5 mm plus 20 inches = 11.04 inches plus 20 inches = 31.04 inch diameter.
275/55/20 is 302.5 mm plus 20 inches = 11.91 inches plus 20 inches = 31.91 inch diameter.
31.91 divided by 31.04 = 1.028 = an increase of only 2.8 percent.
Varies a little by tire manufacturer.
Credit: ponderosajack for that information.
Old Jun 24, 2021 | 09:38 PM
n559br's Avatar
The calculator I show says at 60 mph indicated you'll actually be doing 64.
https://www.tyresizecalculator.com/t...ror-calculator
Old Jun 25, 2021 | 07:06 AM
bkjecu94's Avatar
This calculator shows 60MPH as 61.9MPH using OEM of 31 inches and New as 32 inches (This being a simple approximation, not exact due to other variables not presented in the formula). Not sure what your inputs were for your calculation.
https://www.intercotire.com/calculat...re_size_change
Old Jun 25, 2021 | 07:52 AM
n559br's Avatar
Discount tire has the same 4mph difference. Pdf attached.
File Type: pdf
Old Jun 25, 2021 | 08:35 AM
1979rover's Avatar
Thanks. Yeah, I'mma pass on these.
