Completely new to Land Rover
Old Nov 11, 2022 | 09:26 PM
Ghettoslide's Avatar
Default Completely new to Land Rover
Hello all, I'm the new guy. I'm wanting to get into overlanding and off-road. I always liked the land Rover looks and capabilities. My other option was a jeep. I've never been a fan of jeep. Now here I am a proud owner of a 2007 LR3. With a blown head gasket. I also picked up a 2006 LR3 with you guessed it a blown head gasket. I found this forum looking for info. I plan on doing a motor swap into the 2007. The trick is I want to keep the terrain response working. Which is what I was looking for information on. How does it work, what sensors is it reading . To keep this post from getting longer I believe I have it all figured out with the exception of throttle control and pedal position. I'm trying to figure out how to deliver that info to the ECU with a different motor onboard. I look forward to learning more about this platform and maybe we can learn from each other.
Old Dec 21, 2022 | 09:25 PM
autoarcheologist's Avatar
I thought I was ambitious buying one non-running LRs, you easily beat me! Sounds like a fun project.
Probably not the answer you're looking for, but have you considered just doing the head gaskets on one, then using that one while you swap the other?
Old Dec 22, 2022 | 12:09 AM
Yes, I have considered that and I may just do that. Being a mechanic by trade putting the other motor will not be much issue. The problem will be getting all the info the terrain response needs to keep functioning with a different motor. I plan on keeping the factory land Rover transmission. I will use the trans from one to make my adapter and get it fitted then of course drop it to the one I'll be driving. I do have two other vehicles I drive so I'm in no rush. The more i learn about the 4.4 the more I don't believe it's the problem. It's the electronics around it. We will see.
LL247
Sep 6, 2017 12:44 PM
Brentski
Apr 29, 2015 08:21 PM
Bwatson94
Sep 23, 2014 12:49 PM
transientwolf
Jul 8, 2013 12:06 PM
Absolutryn
Sep 22, 2006 02:55 PM
