Range Rover 03 2 Questions
Old Oct 23, 2006 | 11:19 PM
Kirk Sykes's Avatar
5th Gear
Default Range Rover 03 2 Questions
Have there been any recalls on the O3 Range Rover HSE. That I may need to get replaced while my Rover is still under warranty. If I have my brush bar removed will it leave holes in my bumper and I will have to replace the bumper.
Old Oct 26, 2006 | 06:01 PM
RL Outfitters's Avatar
Default RE: Range Rover 03 2 Questions
There have been no recalls that I know of. When you take it to the dealer, there system will tell them if there is any open recalls on your vehicle. Two answer your second question, yes. There will be two holes in the bumper if you take the brush bar off. You would have to replace the bumper to get rid of the holes.
Old Oct 26, 2006 | 08:20 PM
Just for what it is worth a recall doesn't mean you will be given a new vehicle, nothing even close.
Mike
Old Oct 26, 2006 | 08:39 PM
geoman's Avatar
Here is a list of recall campaigns on the '03 Range Rover. By supplying your V.I.N. to a dealer they can inform you as to which ones have been performed.
Regards,
Geoman
www.eurotekapg.com
General category
Number Date Title
SB1213 11/23/2005 Campaign - Front Differential Inspection/Alignment
SB1042 06/11/2004 Campaign - Headlight Alignment Adjustment
SB133 01/30/2004 Campaign - Rear Suspension Air Spring Replacement
SB137 11/07/2003 Campaign - Steering Column Squeak
SB134 11/07/2003 Campaign - Navigation System Software Update
SB136 11/07/2003 Campaign - Instrument Cluster Reprogramming
SB135 10/24/2003 Campaign - Door Mirror Wind Noise Correction
H119 06/13/2003 Campaign - SRS Side Impact Sensor Fastener Torque
H293 04/04/2003 Campaign - Air Suspension Pressure Relief Valves
Safety related
NHTSA04V489000 09/24/2004 Recall 04V489000: Subframe Inspection/Replacement
Old Dec 12, 2006 | 06:51 PM
smokinwheels's Avatar
7th Gear
Can anyone tell me what are the steps for removing the brush bar from an 04 range rover hse. Does it leave any marks. Is it easy? Has anyone done it before?
avking
Feb 18, 2009 05:10 PM
rtperformance
Nov 11, 2008 10:52 PM
santora4
Mar 30, 2007 01:04 PM
Kirk Sykes
Oct 24, 2006 02:07 PM
dbear
Jul 17, 2005 02:21 AM
