Land Rover Discovery 1 owner
Old Jun 13, 2014 | 04:34 AM
Kel-Tec-Innovations's Avatar
Default Land Rover Discovery 1 owner
I have a 1997 land rover discovery se7.
Purchased in 2008. I do all my own work on all repairs and customization
Exterior:
Desert Tan/Black
Diamond plating black on lower section
Tactical Rovers Bull winch bumper
Extended Spare tire plate
Snorkel
Full roof basket
LED light bar
Clear updated headlights with HID
Clear corner signal lens
Custom front grill
Custom heavy duty ladder
Black wheel arch
Exhaust second muffler delete and located tip higher to exit at driver side bumper and quarter panel
Lower quarter panel trimmed for tire clearance
Front wheel arch trimmed for tire clearance
Rear passenger Window grid protection
Rear trunk window grid protection
Recovery:
12,000 lbs winch with wireless remote
****** blocks and D rings
Tree saver
Tow Strap
Hi Lift Jack extreme with recovery kit
ARB X Air Jack
Traction pads
Shovel
Hi-Lift Jack mount
Rear recovery hook
VIAIR 400P portable high speed air compressor
Wheels/Tires
Toyo Tire sponsored Open Country Mud Terrain 33"
Factory alloy wheel painted gun metal
Engine
4.0L upgraded to 4.6L Fully rebuild
Using 4.0L high compression piston
K&N Cold Air intake
Fan clutch delete
NGK Ignition
NGK spark plug wires
NGK iridium spar plugs
Transmission/differential
ZF4HP22 upgraded to ZF4HP24
GBR 4.11 gears front and back
Eaton Tru Trac front
Eaton Tru Trac rear Tom Woods Double cardinal front drives shaft
Tom Woods Double cardinal rear drive shaft
Tactical rover Differential & drive shaft protection front
Tactical rover Differential & drive shaft protection rear
Suspension
Terra Firma shocks front and back
OME 3 inch lift
1 inch spacer in rear
Terra Firma 5 degree Radius arms
Terra Firma Heavy Duty trailing arms
Terra Firma spring retainers front and back
Terra Firma spring relocating cone front
Terra Firma spring relocating cone rear
Terra Firma Heavy Duty shock tower
Terra Firma Heavy Duty steering arm
Terra Firma Heavy Duty greasable tie rod ends
Heavy Duty adjustable Pitman Arm
Terra Firma steer stabilizer
Relocated steering stabilizer
Extended silicone bump stop
All bushings replaced with orange silicone
Extended lowered sway bar block
Cooling
Aluminum Radiator (testing)
Manually controlled Custom 2 speed electric fan with shroud
External oil cooler with electric fan
External radiator style ATF cooler
Water wetter
180F thermostat
Hood cut and vented
Brakes
Extended stainless steel lines
Slotted and cross drilled rotors front and back
EBC green stuf brake pads front and rear.
Caliper painted desert tan
Interior/electrical
Rear seat delete
Added two fold up chairs
Truck bed spray liner in interior
Aluminum locking tool box
Ultimate gauge
Oil pressure gauge
Oil Temperature gauge
Remote start and alarm system
LED interior bulbs
Two tone door planels
Carbon Fiber trims
Old Jul 13, 2014 | 05:29 PM
TOM R's Avatar
pics of the mods?
Old Jul 16, 2014 | 04:16 AM
Album:
Land Rover - Imgur
Aluminum Radiator
http://imgur.com/a/mq626/embed
Run33
May 11, 2015 09:43 PM
Triumphant
Aug 19, 2011 11:24 AM
Operator
Aug 31, 2010 12:10 AM
shoplacoss
Jan 8, 2010 10:36 PM
