New here and looking for disco advice
Old Dec 27, 2018 | 12:31 AM
chelskisw6's Avatar
Default New here and looking for disco advice
Hey everyone,
I am planning to sell my Rubicon and ‘downsize’ to an older discovery. I’m looking to spend about 5k but hoping to add a number of mods such as lift, bumpers, wheels etc. This rig will be used for Chukar hunting in the desert.
Having never owned a disco, what years and models would you recommend for my price range? What are common problems and what should I be weary of when buying an older one.
Any advice is greatly appreciated!
Cheers!
Old Dec 27, 2018 | 06:51 AM
robert.juric's Avatar
Welcome to the forums.
As as with any older vehicle look for something that has been maintained regularly. I’d pop the hood and look for any oil leaks or coolant leaks. Oil leaks around the valve covers is quite common but easy to fix. The less rust the better. I would ask about the head gaskets and plugs/wires/coil packs. Unless you feel like doing engine work I’d avoid anything that didn’t run smooth or had a tick.
I would look for an 04 with the CDL. First things I would do would be putting in a serviceable driveshaft if it didn’t have one, swapping the thermostat for a 180*, and ensuring all the leaks are fixed. Then address any issues you possibly discover.
Old Dec 27, 2018 | 11:35 AM
chelskisw6's Avatar
Thanks Robert, that's great advice.
Forgive my ignorance, what is the CDL?
What are the driveshaft and thermostat issues that may pop up?
Old Dec 27, 2018 | 12:30 PM
Center Diff Lock. It was on the ‘04 and the guys exist on earlier models but without the shifter.
If you don’t service the driveshafts they could eventually explode and damage the transmission.
The thermostat tat isn’t necessary but would lower the running temps, it’s a common replacement if you end up draining the coolant for any reason. The D2s are notorious for overheating and cracking the block. You could be fine with the standard temp thermostat as long as you keep the coolant system in good order.
Old Dec 27, 2018 | 02:05 PM
chelskisw6's Avatar
Again, thanks for the really helpful info!
My head tells me that these cars will be a lot of work and I should stay with my jeep, my heart tells me I need to go back to my roots and get a Landy
Old Dec 28, 2018 | 11:50 AM
redwhitekat's Avatar
Do you look back at your Jeep after a drive and say dammmm that’s hot ??
If yes don’t sell keep it
if no
than buy a Landy it’s different and it’s dammmm sexy just follow the maintenance suggested on the d2 forum in the sticky’s by disco mike
a must is
tstat to 180
replace coolant with green stuff
driveshaft upgrade
8 mm wires
fuel purge valve
update oil separator to pvc style
all the info is on here
And I don’t know what you mean by downsize
Old Jan 6, 2019 | 07:58 PM
chelskisw6's Avatar
if no
a must is
tstat to 180
driveshaft upgrade
8 mm wires
fuel purge valve
It's pretty sexy but it's no Landy
I will check out the sticky's, thank you! I'll do my best to find a vehicle that has maintenance records so at least I'll have a better idea of what I'm getting into. Anything else I should specifically look/listen for when checking out cars?
By 'downsize' I mean dumping my car payment (and taking on repair costs!)
Daytoman
Mar 11, 2024 06:31 AM
Daytoman
Jan 19, 2019 03:53 PM
TennRover
Off Topic
Sep 3, 2018 10:05 PM
andyblissett
Mar 9, 2007 08:44 PM
