New owner of a misfiring 2000 Disco II!!
Hi everyone, my name is Sam and I am new to these forums. Just purchased an 00' Disco II with 110,000 miles on it, here's the picture:
I am getting a code misfire P0305, cylinder 5. I read a lot about this on the forum for the past few hours - going to replace plugs and wires (hopefully cheaper than the $750 quoted by land rover mechanic).
Happy to be here on the forums, this is the second Disco I've owned.
I experience rough vibration when I press on the gas pedal, likely due to the misfire - even when stationary. When I accelerate on the freeway it feels more intense.
Hopefully its not gaskets or something, I am calling up a dealership on monday to retrieve the maintenance records for this disco.
No, just that one but I've only driven it for a day.
It is going to be something simple. I would buy one spark plug. Pull the wire from number 5 and put that plug in it. Lay it on metal and start. Does it spark? If so, swap the new spark plug in. That might fix it. If no spark, check the wire all of the way back to the coil. Look for burns or cuts.
If none of that yields results, you might have a clogged injector. Not a huge deal to change.
Post what you find.
samroy92 (06-05-2016)
Not when you are checking for spark. That would leave an open hole and a face full of gas.
So, Sam. If you swap the spark plug and that doesn't fix it, put it all back together and go buy a 3 dollar spark plug to check spark, after it cools off again (unless your drove something else to get the spark plug). Or you could get one in advance to check for spark. Your choice.
IMHO a 2000 is the best year. You have the square headlights (glass, not plastic), the first year model (99) anomalies are ironed out, they have the lower compression 4.0 engine, the engine dies aren't all worn out (another member, Chubbs, enlightened me about that), and you probably have the locking CDL that went away from 2001 and didn't return until 2004, lurking just under your truck. Nice!
But I'm biased...
But I'm biased...
But I'm biased...
I think I will just swap two plugs and clear the codes.
Thanks
So I tinkered around with the wires today, I honestly couldn't even pull out the wire after my workout... But I noticed the radio now has a loud cutout and THUMPING noise in tune with the engine.
I am now guessing there is some electrical grounding on the bad wire, cylinder 5. I think I will go for the whammy this weekend and replace all plugs and wires myself.
Anyone have any thoughts on the radio? It's a loud, high frequency cut-out and buffeting. Almost like the radio is being played back via microphone in a windy environment.
--Sam
--Sam
