Discovery Sport - New shock with no adaptive dampers !!
Old May 13, 2021 | 05:34 PM
Louis Limoges's Avatar
Default Discovery Sport - New shock with no adaptive dampers !!
Hey guys. I just received and changed the 2 rear shock dampers on my Disco Sport 2017. I noticed the new damper did not have the electronic connectors but I figured I never used the option so no need for it. All in all, everything is back as smooth as day one but I do get the annoying "Adaptive dynamics fault" in my dashboard. I own a HSE so I guess what I installed is the non-HSE version.
Any quick tip to disable the warning in the dashboard ? I wonder if the wire shorting trick like the brake sensors work but I doubt it since these wires most likely have control voltage for a small pump versus a simple contact sensor.
A resistor on the wires would probably do the job but can anyone provide me on the electrical specs for this wire strip ?
Thanks in advance !
Old May 18, 2021 | 09:02 AM
Thanks in advance !
Anyone knows if I can remove the dampers head to just hook the electronics to the truck ? I see no difference in comfort so I just want the dashboard msg to go away. Thx
Old Jun 17, 2021 | 10:05 AM
Anyone ??
Rysmom612
Feb 6, 2021 06:13 PM
Cchilds
Oct 1, 2019 11:02 AM
RR2006
Nov 27, 2018 10:46 AM
RRS1
Apr 20, 2009 01:43 AM
