question for the limeys
Old Sep 15, 2008 | 12:05 AM
NiteTrain's Avatar
Default question for the limeys
If you guys call a drive shaft a propeller shaft..what do you guys call the propeller shaft on a boat?
Old Sep 18, 2008 | 11:02 PM
NiteTrain's Avatar
Default RE: question for the limeys
anybody? irish and scottish feel free to answer too.
Old Sep 29, 2008 | 06:10 PM
Adz's Avatar
Adz
Hmm... not sure about this one. Drive shaft is the shaft from gearbox to hub on a front wheel drive vehicle - usually. Differential unit on these is usually part of the gearbox or attached directly to the gearbox casing.
Prop shaft is from in-line engine/gearbox/transfer box to front or rear mounted differential in the relevant axle - much in the same way as if you replaced the diff with a propeller the 'prop shaft' would drive it.
From a remote diff, i.e. Land Rover front or rear axle diff, to the hub the shaft there is called a 'half shaft' as it's half the width of the axle.
Dunno if that helps or not
colemtd
Mar 30, 2019 08:57 PM
