Other All other Land Rover vehicles.
Mud under the doors Discovery 2014
Old Oct 30, 2014 | 12:54 PM
MKO's Avatar
MKO
3rd Gear
Default Mud under the doors Discovery 2014
After hunting tour, I discovered that there is a significant mud clumps under the door rims accumulated that are only seen when the doors are open. Anyone has experienced the same problem? Is that normal? If not (and I suspect it shouldn't be normal) what can one do about it? The dealer said that this is normal, but I suspect it shouldn't be.
Thank you for any response.
Old Oct 31, 2014 | 09:14 AM
Jagfixer's Avatar
Mud is worse than water, you can see where you have been. Is it below weatherstripping? If so it is normal.
Old Nov 3, 2014 | 03:32 AM
MKO's Avatar
MKO
3rd Gear
Thank you for your reply! Yes, it is below weatherstripping, the part that goes under the car body. Any ways to prevent it? Or perhaps one shouldn't because it has a purpose (I don't see what that purpose might be though).
Thanks again.
Old Nov 4, 2014 | 09:18 AM
Jagfixer's Avatar
The weather stripping keeps water and the mud out of passenger compartment, anyway supposed to. Dirt lower than weather stripping is normal. Make sure you keep door drains cleaned out and clear of debris.
Old Nov 5, 2014 | 01:08 PM
MKO's Avatar
MKO
3rd Gear
Thanks Larry! Will do.
disco5000
LR4
Jun 26, 2014 03:38 PM
TRIARII
Sights N Sounds
13
Feb 16, 2014 11:09 AM
rezzrover
May 7, 2013 06:02 PM
wynhd
Aug 28, 2012 11:33 PM
Spencerfitch
Dec 17, 2010 10:48 AM
