I was Wondering wht is the best year of the Range Rover to go 4-whelling??
They are all good off roaders. It is hard to say what years would do better and I think they would be equally matched if pitted against each other. One with air springs might be better because it will lift itself a bit higher than if it had coils. A range rover classic 1987 to 1995 has the shortest wheel base which, will keep you from grounding out as much. The p38 1995 to 2002 has the air springs to compensate for the longer wheel base. Most have had their air springs removed because they can be expensive to maintain. In either case, all range rovers are good at off roading and I don't think it will matter which one you choose.
nicksrover
01-05-2015 02:48 PM
