Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
1987 Range Rover Inertia Switch
Old Jan 8, 2022 | 12:04 AM
WellsRover's Avatar
3rd Gear
Default 1987 Range Rover Inertia Switch
I’m working on my Range Rover now just put a new fuel pump in to fix my fuel problem and it seems I have ran into another problem. With the inertia switch down the pump continues to pump fuel even with the key off. And then with the switch up there is nothing. I don’t know a whole lot about the inertia switch but I don’t think it should be supplying power to the pump at all times even with the car off? I know there is a constant supply of power because I currently have the tank out and tested it before putting it back in when I discovered the constant stream of gas
Old Jan 8, 2022 | 08:26 AM
have you checked the fuel pump relay to make sure they are not failed in the powered position
Old Jan 8, 2022 | 03:34 PM
jt27wa's Avatar
7th Gear
Yes id io to the fuel pump relay under the passenger seat also. Check the gray and white wire if I remember correctly for constant voltage or if its been bypassed with a jumper. Stuck relay will do this also, its ihe silver one with a red stripe. Unplug it and see what happens.
Bubba927
Sep 8, 2017 09:19 PM
mcabrera3
Jul 31, 2015 09:25 AM
rrrrralph
May 5, 2013 01:04 AM
HOSER
Jan 1, 2012 10:27 PM
tophur
Feb 11, 2008 12:47 PM
