Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
1990 Classic Won't go into gear
Old Nov 6, 2019 | 04:15 PM
Chad91901's Avatar
Default 1990 Classic Won't go into gear
Hello everyone... I'm a new member and just bought a 1990 RRC. QUESTION: I pulled into a spot after work to wait for my garage door to open so I could back the truck in... When I went to switch to reverse-------- nothing happened.. It hasn't gone into gear since.... The transmission was said to be rebuilt in the past year and I had NO problems with it,,, no grinding,,, no weird sounds or anything previous to the trouble.. ( and I've crawled under to make sure the rod is moving when the shifter is moved from inside) Is this a MAJOR problem,,,,,, or possibly a small one.. Financially speaking, I would like to know before I have it towed off to a shop...
Thanks a lot guys,,,,, I'm looking forward to being a member and the owner of a MOVING RR Classic....
Old Nov 7, 2019 | 05:21 AM
Check the fluid level
Old Dec 30, 2019 | 02:44 PM
88POS's Avatar
Did you ever find a solution to this? I have the same issue with my 88 POS but it has trouble finding any gear. I have not began to troubleshoot yet.
Blade
Nov 2, 2014 09:10 AM
livetoride
Jul 28, 2013 12:14 AM
xb70valkarye
Jun 16, 2011 01:54 PM
all1knew
Jun 5, 2009 12:49 PM
wblogg1
Dec 11, 2008 09:31 AM
