Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Compression Test on a 3.5V8 CR9.35:1
Old May 14, 2024 | 05:42 AM
1986RRC's Avatar
Default Compression Test on a 3.5V8 CR9.35:1
Hello. I have a question in relation to compression tests.
Does anybody know what readings or range in Bar should a healthy, newly overhauled 3.5 V8 efi High Compression 9.35:1 engine should give? Std measurement pistons fitted with new liners.
Thank you
Old May 15, 2024 | 11:45 AM
Harvlr's Avatar
I don’t know exactly the 3.9. For comparison, my 4.6 with 190,000 km is 165-170 psi on all cylinders. I would think your 3.9 shouldn’t be hugely different.
Old May 16, 2024 | 01:42 AM
1986RRC's Avatar
Hi,
Thanks for your reply. Actually mine is a 3.5l. I get readings between 9.5 to 10.5 Bar. I was told in another forum that its actually ok for a newly build engine.
Old May 16, 2024 | 10:39 PM
Harvlr's Avatar
Those are probably good. It’s a good sign when they’re all roughly even, as yours are.
Tommyblack97
Feb 20, 2021 10:48 AM
msm15
Jan 18, 2011 09:54 PM
maxman
Jan 9, 2011 08:18 AM
btbaus
Jan 20, 2010 04:38 PM
arianamini
May 1, 2007 02:06 PM
