Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
MARS or EAS emergency Kit
Old Jul 28, 2023 | 03:43 PM
swissarmychainsaw's Avatar
Default MARS or EAS emergency Kit
Does anyone know of a source for the emergency bypass EAS kit?
Airbag man in AUS is out of stock, and the ones on ebay are over $500!
P38 ones should work fine.
Thanks!
Old Jul 30, 2023 | 12:38 AM
Harvlr's Avatar
Are you trying to get rid of the EAS?
Old Jul 30, 2023 | 11:07 AM
No, not get rid of EAS, this is just the emergency bypass where you can manually inflate individual bags in case EAS fails.
Here are examples:
https://airbagman.com.au/collections...1?lfdnr=178901
https://www.partsrover.com/en/suspen...r-classic.html
Old Jul 31, 2023 | 12:25 AM
Harvlr's Avatar
I see. I didn’t know a kit was available. I tee’d 4 Schraeder valves into my P38 (one per air spring). It was a fairly simple job. I did it a few years ago so I don’t remember where I got the fittings from.
Old Sep 4, 2023 | 12:04 PM
Well, to close this thread, I did two things
1. Went to amazon and bought 6mm fittings and 6mm air line. The fittings are all plastic, but seem to work just fine. I hooked these up to scrader valves and was able to manually inflate my airbags while rehabbing my EAS.
2. I bought a kit from "air bag man" this seemed expensive to me @ around $150 USD. Good things: really good quality fittings that I trust; 200 PSI nylon hose. Bad thing they use 1/4" fittings. This is ok since they are internal ****** and compression fittings. They are not going anywhere.
Compared to the push fittings where the 6mm and 1/4" difference feels more important.
I should take one apart and see if the o-rings are actually different!
Old Sep 4, 2023 | 09:54 PM
Harvlr's Avatar
Good news. Let us know in a month or two if it continues to work well.
dev99disco
Oct 27, 2019 10:03 PM
packkratt
Aug 17, 2017 11:03 PM
ashtray
Jul 2, 2017 07:54 PM
kean
Feb 25, 2009 06:39 AM
simjack
Oct 12, 2008 10:24 AM
