Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Purple wire for what?
Old Aug 1, 2022 | 03:19 PM
From11thProvince's Avatar
5th Gear
Default Purple wire for what?
Hi. What is this purple wire/connector for? It’s purpose? I cannot locate the another one. See the pics.
Ok if I leave it permanently disconnected?
1994 Range Rover Classic
Old Aug 3, 2022 | 03:10 PM
OverRover's Avatar
That wire is the 12 volt positive for the REAR Dome Light/"Courtesy Light" SWITCH.
Check to see if the rear light switch is in place (in the door jamb), then remove the one screw to see how the wire connects (just a male tab).
If you need a new switch they are cheap and can be had at almost any rover parts supplier.
The part number is PRC8548..... GOOD LUCK!
Old Sep 26, 2022 | 02:48 PM
5th Gear
@OverRover thank you for your helpful tip/recommendations. It solved the mystery and the issue has been resolved.
Pierrodisco
Aug 9, 2022 02:05 PM
jrjr5000
May 6, 2022 09:27 PM
Marco Kim
Aug 15, 2021 07:50 AM
jack112286
Nov 20, 2019 12:03 PM
kip lightning
Jun 9, 2015 08:00 PM
