Runs Perfectly - HARD to start - 93 RRC 4.2
Hello, I have been troubleshooting a hard start issue and could use some assistance.
Engine runs smooth and strong at idle and under load. No strong exhaust smells.
very hard to start... takes 4-5 attempts with various number of cranks. Usually between 5-10 seconds to get it to fire up. doesn't matter if its hot or cold.
thought initially the fuel pump or fuel pressure regulator, but again, the car runs fine when i finally get the engine to fire up.
I have also heard that the fuel temp sensor may be a culprit. I unplugged it and attempted a start up. no change when its plugged in or not.
My next step to look at the connections to the starter. but again it sounds strong.
I have read through several forums here, but many have similar issues AND rough idle/ stalling or these symptoms only when hot or cold.
thanks in advance for the input. ill check back.
thanks,
Steve
- ignition amp 1 year old. connectors and grounds look ok
- cap looks fine
- new rotor
- wires one year old
- battery voltage tested fine but not tested for cranking amps.
- battery grounds cleaned
- battery hot lead may show a little age
- oil level ok
- i can hear fuel pump priming when in AC mode, and relay click every time
- coil 1 year old Lucas brand i believe. connectors clean and tight
- starter seems to sound strong
- when in ac mode attempting to let the fuel pump run for a few seconds to get it to fire up... mixed results
- one of the injector connectors was so worn the wire casing cracked off... MAY have shorted on injector 1... repaired... I will test for voltage at this injector
- squeezed the vacuum line to the fuel pressure regulator in attempt to keep some fuel in the rail and re-start. no change.
thanks,
Steve
johnmaambo
Range Rover L322 (3rd Gen)
May 16, 2023 09:49 AM
superzolli007
Jul 22, 2022 08:19 PM
PMPN8EZ
Range Rover Classic (1st Gen)
Jun 30, 2022 02:02 PM
