Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
2015 Evoque - climate control issue
Old Apr 7, 2023 | 08:36 AM
aroby's Avatar
Default 2015 Evoque - climate control issue
My climate control works (AC and heat), however there is fairly often an issue where the air justs shuts off. The fan is still working, but airflow is reduced. In the winter I notice it because my legs start to get cold, in the summer the AC just isn't blowing. If I leave the car for a while, everything then works again. I assume this is something to do with the damper system and/or the sensors, but can't figure out how to get to either to start to diagnose this.
Anyone seen this before or have ideas where to start?
Thanks
Old Jul 5, 2024 | 08:22 PM
donalddave's Avatar
4th Gear
The damper actuators control the airflow direction in the HVAC system. If an actuator is malfunctioning, it might not be directing the air properly, leading to reduced airflow.
Old Jul 5, 2024 | 08:28 PM
donalddave's Avatar
4th Gear
Thanks
gheorghe648
Jul 2, 2022 03:50 PM
tipenidi
Aug 6, 2020 04:05 AM
mx468
Dec 11, 2016 10:59 PM
ljdiscovery
Jun 25, 2016 12:19 AM
RawFaith
Jan 27, 2016 12:43 PM
