Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
2015 Rover Evoque, 2.0 L--Where is Coolant going?
Old Nov 25, 2023 | 03:23 PM
earlyrovertoo's Avatar
5th Gear
Default 2015 Rover Evoque, 2.0 L--Where is Coolant going?
My coolant runs down slowly, with no obvious reason as to where it is going. Where could it be going? No leaks on ground, or around radiator/engine, no leaks into oil pan, no leaking into combustion chambers that I can detect, so where can it be going? Has 2.0 liter Ford engine. No problems otherwise---running good.
Has original Rover red antifreeze; I think they had problems with that, maybe damaging some gaskets, right?
Old Jan 7, 2024 | 08:49 AM
flyingscot's Avatar
Some ideas - Try replacing the pressure cap on the reservoir - ($20 Amazon). Also could buy some fluorescent dye and a blacklight from amazon ($15), check hoses after everything upto temperature. Check oil and look for milky sludge - sign that the cylinder head gasket may have failed.
Celal cinaar
Range Rover Evoque
Dec 30, 2023 12:38 PM
rangeroverman
Range Rover Evoque
Feb 24, 2018 02:34 PM
Matthew German
Range Rover Evoque
Jan 21, 2017 08:13 AM
js8488
Range Rover Evoque
Jul 15, 2014 09:05 AM
mamboo
Other
Jul 15, 2010 01:24 AM
