Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
2017 Evoque brake issues
Old Aug 30, 2017 | 08:21 PM
Darstar's Avatar
Default 2017 Evoque brake issues
Originally Posted by DiscoCam
So I drove my D1 about 70 miles today, did some wheeling too. No issues whatsoever. I've been needing to change my front brake pads so I did so when I got home. I finished the front driver side brakes then went to pump the pedal to bring the fluid level down a bit from pushing the caliper back in. But the pedal just goes to the floor. Makes a squeak too if I pump it fast. I tried to see if I could bleed the caliper and barely any fluid came out. Do I have a bad caliper? If I do, what should I buy? Rebuild the current one, buy a rebuilt one, buy a brand new one? Should I replace both front calipers?
Thanks in advance
I am new to this forum, so tell me if I am in the wrong thread. I just bought a 2017 Evoque, got 3800 miles so far. Tonight while driving in downtown traffic when all of a sudden when I went to stop, the brake pedal went almost to the floor before I could get it to stop ! If I pump the pedal I have hard over sensitive brakes, but it will stop instantly...very unnerving to say the lest. I see no visible leaks on the ground, also my rear camera went dead about same time. I got home , about 5 miles, but am wondering if this problem is common to these vehicles. Thanks for letting me jump in here, if anyone has info, please let me know.
Old Aug 30, 2017 | 08:26 PM
DiscoCam's Avatar
An Evoque has no similarity to a Discovery 1 whatsoever other than the badge. You'll probably get a better answer on the Evoque section of the forum. You should take it to the dealership as even the basic limited warranty will cover that.
Old Aug 30, 2017 | 09:00 PM
split off into the right section
AustinTX
Range Rover Evoque
Nov 28, 2016 03:48 PM
mark0006
Discovery Sport
Aug 15, 2016 12:01 PM
mark0006
Discovery Sport
Jun 16, 2016 08:27 PM
TristanSosa
Range Rover Evoque
May 16, 2013 12:56 PM
LandRoverNews
Defender
Oct 20, 2011 11:20 PM
