Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
Humming sound at around 60-80km/h
Old May 26, 2022 | 05:35 AM
Rish's Avatar
Default Humming sound at around 60-80km/h
Hi.
I get a humming sound around 60 to 80 km per hour. Seems to go away when driving above that speed. From my point it sounds like the rear wheel bearing. Took it to a local mechanic who says it's not the wheel bearing. No broken seals etc. A quick Google search comes up with failing rear differential pinion bearing. Any one experience similar issues. Any advice would be appreciated. 2012 Range Rover Evoque, Automatic, SD4
Update
I had the diff replaced. Pinion bearing. Now I can hear a sound from the front. It's not the wheel bearings as I had these checked out. Are there universal or CV joints in front?
acg
May 10, 2021 01:54 AM
houm_wa
Dec 3, 2014 11:21 PM
ntmichaud
Jun 12, 2011 03:31 PM
hampshier32000
May 10, 2011 11:54 AM
csb
Jun 5, 2010 08:27 AM
