Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
07 Supercharged trailer brake connector location
Old Mar 18, 2023 | 03:24 PM
RIGeek's Avatar
Question 07 Supercharged trailer brake connector location
Hello all. I have an 07 L322 Supercharged 4.2L with the tow package and I've been trying to install the brake controller. I'm in the US and working with a lefthand drive vehicle (if that matters). I have the direct-fit wiring harness for the brake controller and everything I find has told me that the connector is over the brake pedal but I'm sure it's not. I've taken much of the drivers side apart from the kick panel under the door, up to the column and even including the HVAC controls. No 6-pin connector to be found. My vehicle does have the hitch, 7-pin hitch connector and the tow module installed behind the rear storage compartment.
I've bought a 1 month Alldata subscription just to find that the harness and connectors for the hitch are not even listed in that.
Any help would be appreciated on this as I'm supposed to pick up a 5000lb camper in a couple weeks.
Thank you all!
Old Mar 18, 2023 | 09:00 PM
RIGeek's Avatar
I figured it out. My SUV has the tow package but no brake wiring. Now that I've poked around all the wiring in the dash, I have bigger issues. A misfire, no throttle response and a list of codes. p0513, p2123, p2135, u0151, u0167 & p2105.
Ddogmatic
LR2
Jan 23, 2023 09:34 AM
Johnnycat
Aug 16, 2022 06:47 AM
bkjecu94
Aug 28, 2021 09:29 PM
LR disco 5
Jul 22, 2021 07:24 AM
memobug
Mar 28, 2016 06:39 PM
