Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2006 Supercharged Possible Vacuum Leak?
Old Apr 24, 2020 | 10:06 AM
kplatinum777's Avatar
4th Gear
Question 2006 Supercharged Possible Vacuum Leak?
Hi. I have a 2006 Range Rover with the 4.2-liter supercharged engine, which I acquired as a project car
I've had a persistent CEL and when I pulled the codes, it said that both banks were running too lean. That makes sense, because the RR stalls immediately after a cold start, has a rough idle, and surges. I opened the hood and can hear hissing very close to the left side of the engine, near the PCV valve under the engine cover. I have replaced the PCV valve, but it was hissing before that. Since the hissing is significant enough for me to hear it, I'm hoping I can avoid a smoke test and solve it myself. It appears to be a rather large vacuum leak.
Before I take the engine cover back off, does anyone know which components/hoses in that area could be causing the hissing/vacuum leak? (Picture attached for reference)
Area of hissing/vacuum leak
Old Aug 4, 2020 | 02:10 PM
MTRIDGEE11's Avatar
Default Hissing Passenger side, PCV? Intake?
Ho,
Having the same issue. Was thinking the PCV as well
Did you find out what was going on?
Much Appreciated !
Old Jul 20, 2021 | 07:20 AM
coreyb's Avatar
Default Same thing on my 06 standard HSE
you will find it’s your crank case vent or as rock auto calls it. Oil separator. It will be the o rings on the vent inside the valve cover. I found the same issue last night on mine. I had to order from an oem site and part was about $60 shipped. Hope this helps
OCMike
Sep 25, 2019 12:31 PM
Phatrowles
Oct 6, 2013 12:00 PM
willrok13
Jan 4, 2013 12:27 AM
Switzer
Aug 13, 2009 04:23 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
