Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2008 RR HSE with p0960-14
Old Apr 27, 2024 | 07:36 AM
agoritsk's Avatar
4th Gear
Default 2008 RR HSE with p0960-14
i have a 2008 Range Rover HSE, one owner and vehicle has been great.
No major issues.
Until now have completed the following:
1) transmission flush at 160 with replacement of filter/pan
2) rebuilt transfer case??? as there was a leak between transfer case and transmission- 175k miles
3) replaced fuel pump 180k
4) replaced air compressor and 2 front struts
5) replaced valve cover gaskets
6) replaced pcv, maf, and a few hoses
7) replaced radiator
8) normal brake and rotor changes
I've always had some lean codes, mostly left side which came and went.
more recently i have both lean codes. rover runs great, and these codes appear intermittently and haven't been able to figure out he issue. mechanic said i may need to get the ecu reflashed or upgraded which i haven't done.
Now over the last 3k miles, ive had these codes which show loss of communication between the transmission control module, engine control module and the other s
such as
u0403-94 state intermittent- invalid data received from transfer case control module.
u0418-04 state permanent invalid data from vehicle dynamic control module
u0401-94 sate intermittent - invalid data received from engine control module/powertrain control module.
I was able to clear these codes and recently when I cleared these codes, the yellow triangle would display on the dashboard in the middle and the yellow brake warning. when i restarted the vehicle, this would clear, and all would work well.
I had no issues with transmission, no slipping, noise, and rover drove great.
until two days ago. i drove to work in the am, parked my vehicle (no issues).
upon leaving work, i started vehicle and got that dreaded Transmission Fault Limited Gears Only.
I have a icarsoft scanner and i pulled the following codes.
p0301-00 state intermittent- cylinder 1 misfire detected.
p0316-00 state intermittent- misfire detected on start up
p0171-00 state intermittent- system lean bank 1
p0174-00 intermittent- system lean bank 2
u0402-94 state permanent- invalid data received from transmission control module
u0401-94 state- intermittent- invalid data received from engine control module/powertrain control module
u0416-86 state pending- invalid data received from vehicle dynamics control module
u0248-87 permanent lost communication with remote driver utility module
and the dreaded
p0960-14 state- permanent pressure control solenoid A control-circuit/open.
freeze frame data are:
main engine control module voltage supply 14
engine status- engine running- No
engine status- engine in crank - No
External temp 22C
ger information (torque converter status and shift t......)- 30
gear information (torque converter status and shift t...) Open
transmission oil temperature 83 C
actuator supply voltage 12.96 V
transmission output shaft speed 0 rpm
i viewed some other data (car in park)
gear position selected Park
Key lock out put state Inactive
# trouble codes set due to diagnostic test 1
park or neutral signal for starter inhibit - Inactive
pressure control solenoid 1,2,3,4,5,6 drivers- All show 0.05A
shift lock solenoid signal Active
signal information 0- status chip temperature- ok
signal information- status output speed OK
Signal information status park lock- ok
status information 0- status position sensor- ok
status information 0 status transmission oil temperature compared to chip temp - ok
signal information 0 - status transmission oil temp- ok
signal information 0 status turbine speed - ok
signal information 1- status engine speed- ok
signal information 1- status shift lock request - Off
signal information 1- status throttle /pedal- ok
status information 1 status torque1 - ok
solenoid status- state of solenoid 1,2,3,4- All are inactive
status of the ignition on /off switch On
switch input flags- level on L1 pin High
switch on input flags- level on L2 pin- high
switch input flags- level on L3 pin Low
switch input flags- level on l4 pin - high
switch input flags- level on option input pin- high
switch input flags- level on tup negative pin- high
switch input flags- level on tup positive pin- high
transmission control internal module temperature if transmission shu......-40C
transmission control module internal module temperature 20C
transmission current gear - Third (car is in park when these codes were run)
transmission oil temp if transmission shuts down due to over t---- -40C
transmission oil temp sensor(minus) 1.72 V
transm oil Temp sensor 1.25 V
trans oil temp 23C
trans output shaft speed (raw) 0rpm
trans output shaft speed 0 rpm
turbine speed 640 rpm
drove rover home for about 15 miles.. i sensed i was stuck in 3rd gear and so drove less than 40 mph . below 40 mph, no issues when driving. no noise, no slippage.
now rover is in my driveway, and i pulled the above codes.
any thoughts? Recommendations.
should i be concerned about TCU?
can a failed solenoid cause the above codes and the failure to communicate codes.?
any other transmission data i can pull to assist with the diagnostics
any recommendations on who to bring vehicle to for diagnostics and repair?
thank you for your time in advance. this group is amazing.
LR disco 5
Dec 19, 2021 07:15 PM
Onenuttman
Mar 12, 2021 11:28 AM
silvergsx623
Nov 24, 2020 09:35 AM
FlyingZebra34
Aug 7, 2019 05:34 PM
