Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
4.2 2006 Throttle Body/ accelerator pedal issue
Old Feb 9, 2023 | 11:01 PM
huggi's Avatar
Default 4.2 2006 Throttle Body/ accelerator pedal issue
Hello mates, got a 4.2 SC as a project for next to nothing. Was not starting, delivered by AAA. Previous owner thought it was a fuel pump issue which he replaced. He would hold the throttle body open with a screw driver to spray starting fluid in, in turn this was damaged. I replaced the throttle body and it now starts. However when I push on the accelerator nothing happens. I'm getting a few codes
P2105 - throttle actuator control system forced engine shutdown
P2135 - throttle position sensor switch A/B voltage correlation
P0227 - throttle position sensor switch C circuit low
P2123 - throttle position sensor switch D circuit high
I replaced the accelerator pedal assembly with a used unit off fleabay - made no difference (does anyone have a wiring diagram for the 6 pins?)
I checked some numbers
Relative throttle position 5.9%
Absolute throttle position 16.9%
Commanded throttle actuator control 20%
Absolute throttle position B 33.7%
Absolute throttle position D 0%
Absolute throttle position E 100%
Thanks in advance
LRD2&ME
May 13, 2019 09:25 PM
Externet
Jan 4, 2018 01:00 AM
ClayinSA
Nov 29, 2017 10:15 AM
Broken08
Jun 28, 2015 03:29 PM
martin
Oct 8, 2011 01:49 AM
