Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Finally bought a L322 Range Rover
Old Sep 8, 2024 | 07:46 PM
Default Finally bought a L322 Range Rover
Picked up a 07 Supercharged in Java black has demons and rust. Once I replace the alternator I’ll have to decide if it’s a daily beater or a parts truck. It was certainly cheap so we will see
Old Sep 13, 2024 | 07:16 AM
A battery drain was definitely an issue it has. While pulling codes I noticed that it was letting the smoke out of the alternator. Guessing it was internally shorted out. Grabbed one out of a parts LR3 now to swap them in and see where we go
View this post on Instagram
Old Sep 16, 2024 | 01:13 PM
Old Sep 17, 2024 | 08:44 AM
Jesus this is definitely not as easy as the alternator on the RRS or LR3. I’m 99% sure I have to pull the fan and shroud to get it out and the new to it one in
Old Oct 27, 2024 | 06:52 PM
Ok I was able to fight it out and get the new used alternator installed and back together.
Been working through its other issues and cleaning it, then cleaning some more and then again
Old Oct 29, 2024 | 07:56 AM
So the paint was looking pretty thrashed when you looked at it. I know it has rust holes but what the hell lol
so I broke out the buffer and the secret sauce and got to work
a long time later we had this
Old Oct 30, 2024 | 10:03 AM
Took it out for a quick spin
Old Oct 31, 2024 | 08:14 AM
Well the first on road trip went as expected
some minor issues otherwise drove very well. A few codes popping up after sitting for a year or two unused is no shocker
Old Nov 1, 2024 | 07:27 AM
Pulled the wheels to check the brakes found the damaged sensor lead on the right rear. Also found all the tires were badly dry rotted and cracking throughout the tread. So I pulled a good set off a parts LR3 for the time being. So it’s riding on 19’s for now. Those Brembo brakes are massive! Had to play my favorite Land Rover wheel game a few times and found a split cv boot on the right rear as well.
Old Nov 4, 2024 | 07:28 AM
Work continues
