Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Indicator are going mad
Old May 26, 2024 | 10:17 AM
Ernest-0107's Avatar
Default Indicator are going mad
I have a 2007 RR L322 4.2 S/C and I am experiencing an issue with the turn signal. When I try to signal left, the vehicle signals right. When I try to signal right, it signals right. The hazard lights work without any problems. This issue occurs sometimes right from the start and sometimes only after 5 minutes, but once it starts, it doesn't go away. The battery has been checked and is always connected to power when the car is parked. The steering column switch has been replaced, and the LCM has also been replaced. But the problem still persists. Does anyone have a solution?
Thank you, as I am at a loss and the Range Rover dealership is also unsure."
MountainDewfus
Jan 3, 2024 08:28 AM
defenderobx
Defender
Sep 27, 2022 08:31 AM
defenderobx
Aug 5, 2022 01:55 PM
alpinacsi
Feb 7, 2018 08:45 PM
starcraft
Jul 6, 2011 07:58 AM
