Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
L322 4.4 TDV8 damaged ecu
Old Jun 7, 2021 | 01:33 PM
armilaa's Avatar
3rd Gear
Default L322 4.4 TDV8 damaged ecu
Hello
2011 L322 with 4.4 tdv8. Tried to put stage 1 tune to my ecu. Computer lagged and and i had to start again. When it completed i tried ecu in car but car wont start now... I restored backup which i made earlier but it does not help. I can read and write ecu with ktag. But when i try to read fault codes fault code reader it just says unable to read fault codes. But still i can see version information etc with fault code reader.
And yes i checked all the pins of ecu. All other ecus gives fault code about connection to engine ecu.
Can i buy just some random edc17cp11 ecu or does it have to be from 4.4 tdv8 range rover?
Old Aug 19, 2021 | 01:17 PM
Bobski's Avatar
Default 4.4 tdv8 ECU
Originally Posted by armilaa
Hello
Did you ever sort this ??? I have a similar problem,
Old Sep 25, 2021 | 12:19 AM
armilaa's Avatar
3rd Gear
I restored backup and it sorted it.
Tune was damaged or faulty. I got new tune from supplier and it worked.
joran
Defender
Dec 23, 2016 02:38 AM
andrewfaber
Jul 19, 2016 12:08 PM
aftermath431
Sep 18, 2013 09:07 PM
willys_49
Nov 10, 2012 07:42 AM
JRdisco1
Aug 25, 2005 03:07 PM
