Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
L322 Cranks but No Start - No Code - Fuel Pump at 50psi when jumped
Old Aug 17, 2023 | 01:41 PM
Gnoel's Avatar
Default L322 Cranks but No Start - No Code - Fuel Pump at 50psi when jumped
Hello all, I am new to the forum. I have a 2004 L322 HSE with 130K miles. I just bought it 6 months ago and have limited knowledge of what has already been done to it. The vehicle has ran great but now has a big problem. It cranks with no effort to fire a cylinder. First though was starved for fuel and probably has original fuel filter. Ive read a lot of posts and have done most common checks.
Issue 1 - The fuel pump isn't running when i turn the key on. And i am getting no pressure on fuel rail. I have power to the relay and have swapped the neighbor relay to make sure it's not the relay.
Issue 2 - I jumped out the relay and the fuel pump runs. It delivers 50 psi to the fuel rail solid. But then it still doesn't fire when turning over.
Issue 3 - I have had no OBD codes. (I did disconnect the battery for a while hoping for a "reset" of something. So now I have suspension error etc but I'm sure it's because it can't calibrate while being strapped down to my car trailer.
Issue 4 - i disconnect breather house to the intake and used starter fluid. A few cylinders fire when I do that. And with the fuel pump running, It almost runs. I had the intake valve unplugged and propped open enough to squirt start fluid into. But the point was to check to see if there was spark.
So, the conclusion is that I have the three things needed, just not all at the right way.
Question - With no codes, where do i begin?
All tips greatly appreciated!
Old Oct 4, 2025 | 12:37 PM
geoffvan's Avatar
Did you ever resolve? I am having the same issue.
To update my thread, after ruling out various things ( but not fuel pressure), I decided to see if adding additional gas would resolve. Gas tank was at just under a quarter. I added 3 gallons and it started. So it seems like a jet pump issue (blocked or not working). I just had the fuel pump replaced about 3 months ago with an OEM part.
redrover75
Jul 2, 2023 12:57 PM
sayeedA
Mar 12, 2022 10:44 AM
Dylan Webster
Apr 29, 2019 12:59 PM
tedlit
Feb 26, 2009 01:47 PM
CraigR
Jun 28, 2006 02:26 AM
