two years ago I deleted the AGR and DPF (software + mechanically+ balnking plates).
For the last two years the car ran perfectly, since now!
My Range Rover LM322 / 2008 is now showing following symptoms:
-While starting the engine idles at 500 even though I push the pedal down the revs do not go up. The car is not drivable as there is no thrust.
I have to mention that we have changed the following parts:
Akward is that the car shows this symptoms when I drive it for 30 min and then want to start it again, meaning the engine has to be warm/hot. Once the engine is cold everything works pefectly. Since now nobody could find the error.
I will post a video of the error below.
I would be very thanful for any hint or tip.
