Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
looking for a real expert
Old Aug 27, 2023 | 06:19 AM
Steven911's Avatar
Default looking for a real expert
Dear members,
two years ago I deleted the AGR and DPF (software + mechanically+ balnking plates).
For the last two years the car ran perfectly, since now!
My Range Rover LM322 / 2008 is now showing following symptoms:
-While starting the engine idles at 500 even though I push the pedal down the revs do not go up. The car is not drivable as there is no thrust.
I have to mention that we have changed the following parts:
-New turbos
-new diesel filter
-new fresh diesel
-new battery
-new turbos hoses
-new coolant
Akward is that the car shows this symptoms when I drive it for 30 min and then want to start it again, meaning the engine has to be warm/hot. Once the engine is cold everything works pefectly. Since now nobody could find the error.
I will post a video of the error below.
I would be very thanful for any hint or tip.
Thank you a lot
Steven
Video of the error:
Old Aug 30, 2023 | 12:17 AM
sjz's Avatar
sjz
I would take it to a good car electrician.
It looks like CAN bus fault. Probably some loose connection shows up when engine bay is hot.
Good luck!
RRS2
May 9, 2022 07:15 PM
Craig_RRS2013
Nov 17, 2021 09:48 AM
mti88m3
May 29, 2014 04:47 PM
97LANDISCOVERY
Feb 7, 2008 09:38 AM
