Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
rpm continues to climb after letting off the gas pedal
Old Jul 9, 2018 | 07:33 AM
abeabe's Avatar
5th Gear
Default rpm continues to climb after letting off the gas pedal
Hi all. I have a 2008 Land Rover Range Rover 4.2L Supercharged full size. I am having an issue when letting off of the gas pedal at low speeds (under 25 mph) where the rpm will continue to climb for a few seconds to about 2,000-2,500 rpm. Some things I have tried are cleaning Mass Air Flow Sensor, cleaning throttle body, replacing PCV valve, changing Air Filter. Still have the problem. Could it be an issue with the Supercharger? Any thoughts would be greatly appreciated.
Old Jul 9, 2018 | 07:54 AM
ahab's Avatar
No codes? Does it slowly lag down to idle or does it return normally after the initial run-on? A faulty or misaligned Throttle Position Switch will exhibit those characteristics.
Old Jul 9, 2018 | 08:30 AM
abeabe's Avatar
5th Gear
Thanks for your reply Ahab. I have no codes. The rpm returns to normal after a few seconds after I let off of the gas pedal. The surge in the rpm after I let off of the gas pedal can happen several times on the same drive at speeds under 25 mph stop and go traffic or in parking lots. More noticeable on hot days. It is not a persistent problem but happens several times a week.
Old Jul 9, 2018 | 09:19 AM
ahab's Avatar
I will concede that I know very little about supercharged Range Rovers however the function of the TPS is to tell the ECU that the throttle plate is closed, and therefore to cut fuel delivery back to idle maps. If your truck has a TPS, that's where I'd look.
Old Jul 10, 2018 | 03:28 PM
abeabe's Avatar
5th Gear
Thanks. I will look into it and let you know what I find out.
ChuckRow
Nov 3, 2013 09:27 PM
SHAGUAR
Feb 14, 2013 09:20 AM
LRD2&ME
Aug 8, 2011 10:09 AM
apcollin
Nov 30, 2009 07:23 PM
fanatic516
Nov 26, 2008 01:50 PM
