Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
2014 L405 running light doesn't stay on.
Old Sep 23, 2022 | 01:40 PM
zwayneg7's Avatar
Exclamation 2014 L405 running light doesn't stay on.
Right side running lights won't stay on when the vehicle is running. They stay on for 10-120 seconds then turn off when engine running. Only the right side has an issue. If the vehicle is not running, the lights stay on as it should... I have swapped lights and tested on other side and no issue with the light as well as tested another light on that side(same result). All other lights function normally. When scanned I do have a right rear daylight fault and cannot be reset, also the actuation test fails and does not work (no light when on). Could it be the BCM? What should I try next, I'm out of ideas. Thanks in advance.
el_rev
Jan 19, 2022 05:21 PM
naivedisco2
Jul 10, 2017 08:38 AM
philwarner
Oct 19, 2014 10:41 PM
Harris97
Jul 11, 2011 05:15 PM
Vorhees
Sep 11, 2008 03:42 PM
