2015 Ranger Rover v6 (L405) - Rainbow Dashboard - Electrical Issue?
Hello everybody, I am having issues with my Range Rover today where I got a bunch of dash messages including (ABS Issue, Parking Break Fault, Stability Control, Stability Control Fault, HDC, Emergency Break). So I assume its something electrical because its touching different systems.
I have already checked the ground wire behind the wheel well, ground wire under mass air flow, ground wire connected to trans, and did a battery reset. All grounds look good and not corroded.
Resting Battery Voltage: 12.3v
Running Battery Voltage: 14.7v
Anyone have any ideas on what may be going on here?
How old is your battery? Even though the battery readings are normal, it could be beginning to go bad and causing these issues. Hook it up to a OBD scanner and see what kind of codes it is throwing.
pwcrossl
Discovery Sport
Dec 12, 2023 01:55 PM
