Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Radio Stopped Working, starts after 90 minutes
Old Mar 13, 2026 | 04:01 PM
Ryedalerover's Avatar
Default Radio Stopped Working, starts after 90 minutes
Hi All,
We have a bit of a mystery fault on our early 2020 Range Rover Westminster. We love the car and have only had it for a few months and suddenly the radio has stopped working along with reversing sensor noise and phone connection. Our local Land Rover specialist is at a loss. We've checked for faults on the computer (none), updated all software, checked for any water ingress (none) and changed the amp. Nothing has worked. The mystery deepens as after we've driven for 90 minutes it kicks in, radio works fine as does connection for our phone, etc. If we stop the car, say to refuel, and restart it won't be working again and takes another 90 minutes. We do a few long journeys each month, so have tested this a few times. I wonder if anyone has any ideas as it's stumped us?? Many thanks!
Old Mar 15, 2026 | 08:15 AM
wcc18999's Avatar
That is a strange one. Have you pulled the radio out of the dash and traced all the wiring to check for any loose connections? Your issue appears to be electrical in nature and likely caused by a loose connection. I would also check the on/off button for the radio as it may be the culprit. Good luck and let us know what you find out.
MNDefender
Jul 26, 2022 08:33 PM
Bbg
LR2
Apr 23, 2022 08:12 PM
KlamathMatt
Jan 14, 2017 09:47 PM
SUMOSINO
Mar 26, 2016 07:02 PM
SUMOSINO
Audio/Visual Electronics
Aug 14, 2006 04:35 PM
