Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Better on- off-road tires?
Old Aug 31, 2024 | 03:11 PM
Kickinthetires's Avatar
6th Gear
Default Better on- off-road tires?
2017 RR SC with 275 45r21 tires. I’d like to find tires better for light off road use but nice for the 90% on road I usually drive. Nobody seems to make such a tire in that size and all the wheel/tire posts just confuse a relative novice like me. Not opposed to changing rims as well as tires if there is a plug and play option. Anyone have thoughts?
Old Sep 1, 2024 | 05:42 PM
I would take a look at Nitto they have a few options that I think might fit your needs
Old Sep 1, 2024 | 05:47 PM
6th Gear
Default 21”?
Thanks for the reply. I checked the Nitto site: no 21” made…..
Old Sep 2, 2024 | 11:42 AM
wcc18999's Avatar
Check the BF Goodrich website.
Old Sep 2, 2024 | 11:43 AM
wcc18999's Avatar
Also check the Falken website. A lot of off-road enthusiasts like their tires.
Old Oct 20, 2024 | 02:14 AM
Sandgroper's Avatar
Default Tyre size question
Hi, here in Australia the conventional wisdom seems to be that the 20" rim is the best option as that is as small as the brake calipers will allow and a reasonable choice of tyres. 275/55r20 will fit without modification although I'm about to fit 275/50r20 Pirelli Scorpion ATRs on a set of 20" rims off a D5. Hope this helps.
map4774
Sep 11, 2021 06:55 PM
Mando
Nov 15, 2020 06:59 PM
sn1987
Tires
Dec 30, 2009 11:11 AM
krisstorms
Mar 1, 2009 07:59 PM
ajb
Sep 4, 2007 04:10 PM
