Suggestions on Airing Down Tires
Old Sep 10, 2021 | 05:46 PM
map4774's Avatar
4th Gear
Default Suggestions on Airing Down Tires
Does anyone know or have a preference as to what PSI they run their tires when off-roading?
I'm assuming that for my tires, the OE "off-road tire" option, that I should lower them from their ~ 50PSI down to about 30-35. If it helps I have a 110 P400 and am planning to do light to medium off-roading to get to camp and fishing spots up here in the Rockies, think around Leadville and Aspen Colorado if anyone is familiar.
Old Sep 10, 2021 | 06:07 PM
umbertob's Avatar
Especially if you have 20", that's about as low as you want to go in my experience, unless you are driving on soft sand dunes, in which case you may want to deflate them a lot more than that. I never felt the need to air down to anything less than 32-33 with my 19" Duratracs, and especially with the lower profile and tender "reputation" of the 20" Adventures, which are perfectly fine tires for most light off-roading otherwise, you want to minimize the chances of pinching and slashing a bulging sidewall against a sharp rock by deflating them too much. The 47-50 PSI recommendation for on-road is intended for a fully loaded vehicle, by the way. If you will be driving solo or with just a couple of passengers and little or no cargo (and don't tow anything heavy) on a regular basis, you will be a lot more comfortable airing down to the "Light Load" setting as indicated in your owner's manual, changing the TPMS sensitivity accordingly.
Old Sep 10, 2021 | 06:56 PM
Juancl's Avatar
I have the Adventurers but on 18s (P300) and usually lower them to 30 and they work like a charm. As @umbertob said, would not recommend below that given the experiences of others (soft side wall).
Enjoy!
Old Sep 10, 2021 | 08:37 PM
Kev M's Avatar
We DO use it in sand dunes/beaches
So we take our 19" street tires down to ~20 for that.
Old Sep 11, 2021 | 06:55 PM
map4774's Avatar
4th Gear
Thanks for all the suggestions.
I went up to a lake today in the light load PSI because I didn’t bring my compressor, mostly because it was kind of spur of the moment, and it went well enough. I’m sure dropping them a little lower might have eased the lingering hesitation I had in going over certain rocky segments, spots that have popped tires in other cars I’ve been in before. But the defender has got so much torque, and the locking diffs, and the ability to raise the air suspension, that the whole mini adventure was a breeze.
85Red110
Defender
Jul 16, 2011 01:28 PM
ShadowMerchantBC
May 24, 2011 12:24 PM
trev0006
Tires
Nov 4, 2009 09:33 PM
krisstorms
Mar 1, 2009 07:59 PM
drzjoint
Tires
Mar 26, 2008 08:35 AM
