Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
DTC U0001-81 from multiple modules
Old Aug 24, 2024 | 07:29 PM
Andreas's Avatar
3rd Gear
Question DTC U0001-81 from multiple modules
Hello,
I have a 2014 with a CAN BUS issue is appears. Attached my Autel scan report. Car drives fine and randomly the dash lights up with errors for ABS, stability control, power steering and more. Power steering is noticeably not working during the error. After 15-20 minutes the problem goes away.
The errors are intermittent.
I am getting DTC U0001-81 from the following modules:
TCM (Transmission Control Module)
PBM (Parking Brake Control Module)
TCCM (Transfer Case Control Module)
CHCM (Chassis Control Module)
CHCMB (Chassis Control Module B)
I'm also getting code U0415-08 from the PSCM (Power Steering Control Module)
Battery appears to be good, otherwise the Autel would have told me. I still have to check the fuses.
Could it be as simple as bad contacts? from corrosion or something?
Any ideas would be more than welcome!
Thanks,
Andreas
Old Aug 25, 2024 | 04:11 PM
wcc18999's Avatar
I would check the ground.
Old Aug 26, 2024 | 06:28 AM
Andreas's Avatar
3rd Gear
From what I was reading, this could indeed be the problem. Ill report back once checked.
Old Aug 26, 2024 | 11:29 AM
Andreas's Avatar
3rd Gear
Would you or anybody have an electrical schematic showing the ground points for the L405 Range Rover Vogue? I have found some but dont think it's for the right model.
Thanks!
Old Aug 27, 2024 | 08:25 AM
wcc18999's Avatar
I do not have the electrics schematics, but I assume you could find it online. Good luck. Do a load test on your battery. Autel will not load test your battery, it will only read it.
Old Jun 23, 2025 | 04:58 PM
sam16sam's Avatar
Default a
Originally Posted by Andreas
Hello,
Thanks,
Andreas
hi did you find solution ?
Gargar1970
Jul 29, 2024 02:05 PM
Sportysport14
May 4, 2024 01:19 PM
wehtjns
LR4
16
Jan 30, 2024 02:41 PM
trstefani
Dec 20, 2023 03:30 PM
bluetick
Jan 6, 2019 08:31 PM
